I need an audio interface for my iMac. Sooner or later it has to happen.
I have been offered an Apollo x4 used for 1270 pounds final offer with the normal plug-ins (NOT heritage) plus the following:
Brigade Chorus
Cambridge EQ
-Neve Preamp
-Studer A800
Although I dipped my feet in the pool with a PreSonus Firestudio and Reaper on my old macbook 2012, I decided it was time to get an interface I could use with my 2019 iMac (3.6GHz 8 core i9, 8GB memory, 1TB SSD). Any hurdles will put me off. I want it up and working immediately with little to learn.
For my electric guitar I play my amps through a UA OxBox connected via OPTICAL IN. All necessary compressor and reverb is taken care of inside the OX.
Bass guitar can go through the OX or the Hi-Z and the AMPEG plug-in
Keyboard and Hammond Clone to LINE 1 & 2
Vocals and Voiceover work with a Shure SM58
Yes, I could just use an Apollo TWIN as it is unlikely that I will play along with someone. Recording will be alone. But seeing as the X4 price isn’t too far from the price for a new TWIN QUAD, I may as well go for this. The extra inputs could help with an eventual resale if it all goes sour.
I like the idea of going with LUNA from the get go. The integration makes my life simpler (it took a while to get used to the Presonus) and I look at Reaper with horror.
The music I'm going to record: 60s/70s soul jazz, funk, New Orleans funk and 80s/90s hip-hop. Think Beastie Boys of Paul’s Boutique and Ill Communication.
Drum beats will be programmed on LUNA. Can I get anywhere close to the James Brown sound on there? Clyde Stubberfield and Jabo Starks style.
I can’t see myself falling down the plug-in rabbit hole.
Pros:
Near Zero latency
Free LUNA DAW integration with iMac
More than enough inputs (I can leave all my gear plugged in and never have to search for cable and so it’s ready to go once everything is powered up).
Quality Microphone Pre-amp
Quality Headphone amp
Optical input for my OX
EASY SET UP and UTILITY
Cons:
Overkill
Expensive
REALLY expensive. Couldn't that cash go on something real like a Rhodes Piano?
If you think I should go with another interface, please say. Bear in mind that the DAW choice is important and would be another cost to bear. I probably could stick with Reaper or even live with GarageBand. Latency is a huge issue too. The more processing power the better to reduce latency.
Since you’ve got a Mac, use the money on Logic Pro and a ‘good enough’ 8x I/O like Focusrite. You get all the native plug-ins at a fraction of the cost.
Any suggestions for a reliable Focusrite? Is the mixer control integrated into Logic Pro automatically or is it something I have to deal with manually? Forgive me, I'm just trying to eliminate these little technicalities that tend to put me off.
If someone could guarantee me professional results without any noise and near zero latency on a lower priced product, I would happily save the money (especially since I just invested in a decent chair for all my time spent at the mac teaching online, video editing, and soon audio recording/mixing). Perhaps LogicPro is the way to go with a lower priced interface?
I'd like to pose a question. If one of the people you teach video editing to came to you and said they wanted to do it as easily as possible without any learning, would you tell them to go and blow nearly £1300 on some software because they don't want to learn on something cheaper and a little bit more complex?
I ask this because your approach seems utterly scattergun. You don't want to disappear down the plugin rabbithole but you're up for buying an audio interface with plugins assigned to it. When you talk of Apogee Duet 2 interfaces as being a bit Youtuber, frankly it sounds like you're delving into a field where you don't know very much but you're prepared to spend a lot of money. If I may quote again:
"If someone could guarantee me professional results without any noise and near zero latency on a lower priced product, I would happily save the money (especially since I just invested in a decent chair for all my time spent at the mac teaching online, video editing, and soon audio recording/mixing). Perhaps LogicPro is the way to go with a lower priced interface?"
Before you drop £1300 for an interface, you want to record and mix. So go through the whole setup. Are you recording and mixing in an environment that has been set up for it? Do you have monitoring?
Then there's the windows vs mac mentality of a rational mind vs playful: I just want to plug and play. Any assigning requests and I get anxious.
From what I've seen Apollo X range provides but at a cost. I would deeply appreciate if anyone could suggest a solution that guarantees ease of use, zero latency. As I have Thunderbolt, doesn't it make sense to use it?
Four extra plugins are not many. I do understand that the 'sound' is important, not simply the recording.
I will be doing the same thing: just recording myself.
Perhaps the extra DSP is redundant considering that I can add FX during mixing and rely on the iMac's processing to handle it. I assume the DSP in the interface is to help with Live plug-ins. Or do they also help with latency on direct recording (without FX) and AD/DA?
Perhaps this is the real question I should be asking myself:
What features do I need? Other than I/O, what should I be looking for?
Is the Apogee Duet 2 the same as the Apollo X internally? Is the processing power very different? Are the preamps similar quality?
I really do appreciate all your help with this. It's a field I am quite ignorant in.
If you've got Thunderbolt then it's another variable that says to use it. However you have to weigh that up against cost of interface and expertise. Does that slightly better latency justify spending X more pounds? I'm looking at Andertons now and the cheapest Thunderbolt interface is £535.
Looking at the gear you are using, you want to use the SPDIF output from the OX Box. This has optical and coaxial outputs. So any interface you choose needs a SPDIF input. Now the Ox Box goes up to 44.1kHz so arguably you don't need anything that trumpets its ability to go up to 192kHz.
At the lower end, I'd buy the Native Instruments Komplete Audio 6 on the basis that it's not expensive, decent drivers, easy to use, and it's got SPDIF in and out. Yes it will do low latency guitar stuff. If I can get one of the lower spec Komplete Audio 2 interfaces working well with Helix Native on a slightly frustrating i5 laptop, then a KA6 on a swanky Macbook will be fine.
Finding a DAW that suits you is trickier so I say get an interface and then get busy with Garageband. Upgrade as you need to, not as you think you need to.
https://en.antelopeaudio.com/products/zen-tour/
I wonder if this could be an affordable alternative.
