Bit of a rather specific query…..
can anyone tell me what a typical string clearance on vintage dc juniors was above the single P90 when set up for a decent low action? I have been revisiting my very first two builds ( re-levelling and recrowning the frets, and making better nuts etc) and wondered whether my P90s are too close to the strings - I get some pickup slapping when playing reasonably aggressively. Both guitars have about a 3 degree break angle and are as close to vintage measurements as I could get em otherwise.
Would appreciate any info
cheers
My understanding is that while the measured height of strings above frets etc, might be interesting, even helpful, the real answer is 'when you don't get any interference with the vibration' when it's played as you intended/expected.
If that's the case, I guess you have your initial answer.
Check the neck relief first. If its very loose try and get relief at 8th fret to be around the thickness of the B string. If you need to tighten the rod alot then you may need to raise the bridge a tiny bit anyway to get medium action.
I am interested to find out whether original dc juniors had a relatively small gap, or even whether my P90 cover is high compared to originals. I know a few guys here have late 50's originals.
On my builds the gap between the top of the P90 dogear cover and the strings is approx 1.5-1.75 mm.
cheers
now about to crank it up and adjust the pole pieces to taste - the Firewatch is a great P90 but can really sting a bit on the treble side ( as it is designed to !! )
cheers, advice is much appreciated.
