I've got the head and H&K 1x12 cab and they're good, versatile, well-spec'd amps. I spoke to H&K's product specialist before I bought mine and Thomas Blug and they recommended this set up over the combo and said to "their ears" it sounded better. Try both and see for yourself. The sounds are pretty generic and I prefer to run pedals into the clean channel (quite spanky if you want it to be) and get my overdrives from various pedals but there's nothing wrong with the Crunch and Lead channels.
The head weighs 17lbs- mad for a loud 36w amp and there's enough general volume and clean headroom for gigging. You can use it for recording straight to a unit via the Red Box Speaker Simulator or take a line out to a desk and the PA. If you've speaker cabs at rehearsal places, all you need do is turn up with the head. However, although the 1x12 new is on the pricey side, it's the best 1x12 I've ever heard and it has a lot of thump to it and doesn't sound as one directional as some units.
Bright Onions make a good channel switcher which works well on these.
My band - Crimson on Silver For sale - Blackstar HT-5S
Gear - Guitars, amps, effects and shizz. Edited for Phil_aka_Pip, who is allergic to big long lists.
if you're ok with using the master volume it should be ok. then again if you're ok with that virtually any wattage should be ok.
@Monkeybone
That'll learn me for looking late at night with my shitty eyesight, I read it as Grandmeister for some obscure reason. DOH!!!!
OP I had the 18 watt head and it was a really nice amp and only moved it on because I wanted just a wee bit more headroom due to a proper loud tubthumper in the band. I used it with a 2 X 12" Celestion Vintage 30 loaded Harley Benton cab. Thye seem to sound a bit nicer to my ears through V 30's and I think all the H & K TM cabs have V 30's
Would love to get the GM36 in due course and it is good to hear from Monkeybone that it is still floating his boat and survived the honeymoon period and all that jazz.
