If they can, great....but there is only 1 way to find out.
Same with Klons - all the copies sound broadly the same to a close degree, unless directly A/B’d - they sound quite different from Tube Screamers though, and I think you could tell if it was a Klon or a TS. (At least if you’re using it as an actual overdrive.)
I'm using vox amps and my ears.
I really don't get this clean boost bollocks though. Its *NOT* a clean boost - its a boost but not 'clean', as in a linear raising in level. And whats the point in buying an expensive overdrive just as a level boost? Genuinely there are pedals out there that can do that for sub 50 sheets that I'm sure few would be able to tell apart (when used in that way) from the 'real thing' - and if the Soul Food sounds 80-90% of the Klon (and the expensive diodes are not engaged when used in that way), genuinely there are *much* better boosts available.
But hey... follow the unicorn tears.
Not sure how successful it will be, so just experimenting with cheap alternatives to the real deals. I think they will be good enough to tell me if the general idea can work for me. Not convinced but I’ll give it a go. This thread makes me even more doubtful!
”this torchlight looks bad” vs “this torchlight looks good” when one is being shone into an art gallery and one into a teenagers bedroom.
IMHO after 14 years of owning one, the best setting is gain 9 or 10 OK with an amp at the point of breakup in a two guitar band or one with silly things like keys backing singers sax kazoo and the like.
In that application its subjectively the best overdrive I've tried or owned. At home I use a king of tone.
With a HRD which I'm not a fan of I've found a tube screamer or full drive to sound the best. rat if you want more gain.
Also if the amp is wound up the overdrive pedal becomes less important. You've played through my matchless at high volume and it sounded great
What I tend to like is when the pedal works into a mostly clean Fender-ish style amp—I rarely get the chance to crank an amp to the point where it sounds good and compresses enough for me—and where it adds a bit of coloration, maybe rolls off a little bass, and adds some soft clipping.
So: the ODR-1 (with a bass control) and Timmy designs all sound really good to me, through most things and at most gain levels from just barely on all the way through to flat out. Also really like the Mad Professor Royal Blue, which has a lovely clean up when you roll the volume down (it does that fuzz face impedance thing). For the not-really-breaking up clean boost with a tiny bit of hair/compression, I also really like the Durham Sex Drive (I built a copy) and the Barber Half Gainer.
In fact, I like a lot of things that aren't TS or Klon style pedals just fine.
I also like using a compressor in that role with the gain a bit higher than unity and the compression set somewhere between low and middling levels of squish, e.g. something like a Thorpy Fat General.
If a pedal only sounds great pushing a specific overdriven valve amp at gig volume, that says more about an overdriven valve amp at gig volume than it does about the pedal...
Let's face it TS9 or similar into a Plexi/800 is literally a godlike experience, and has been utilised by a million bands, same with a Rat. The Klon is/has been on multiple pro boards into loads of different amps. Every combination works for someone, some more than others for sure. TS9 into a Marshall though is the nuts for me, then a Klon to smash it over the edge, amazing.
The yard is nothing but a fence, the sun just hurts my eyes...
Back to real volumes I use my favourite one to work in various applications.
I opened it up to look and the diode options - middle was bypassing them - basically being a clean-ish op amp boost. The best sound was ‘more amp’ !
I want to have a lead tone similar to changing the amp to a different channel with a footswitch. My little blackstar my-1rh has no such ability.
I'll keep on looking for a genuine overdrive sound.
