One software update can dramatically change things though in terms of stability so I would suggest established companies with an ability and desire to sort problems- Focusrite, Audient, Presonus, MOTU, UA etc.
However, it can be those super fine margins at the top that make a difference.
I've used an 18i20 for years, and never had an issue, and never had anyone complain about the sound quality! well, apart from my singing ha
Yes there is a difference between entry level converters and top end DAD/Prism etc but if you don't have a great sounding room and excellent monitors then you won't hear it.
Most people aren't mixing for commercial release and the issue is going to be their mixing ability before anything else.
Converters are the last thing I would worry about in 2022- acoustic treatment is so much more important and almost everyone ignores it.
If you can't hear it, it makes no difference. Without wanting to sound even more negative, even in an environment that can portray it you may not hear it. Finally, even if you can hear it, you need to know what to do with it.
I've always been fascinated by the engineering/mixing/production process and have been lucky enough to spend some time with folks who know what they are doing. It's art and science combined and I quickly realised that the ramp to any level of competence and the investment required to create a space worth bothering in, was futile.. not saying it can't be fun but..
Si
You will be able to hear it in an excellent room with top shelf monitors, which almost no one here has- because it is fucking expensive.
There is a reason that professional producers spend a lot of money on room/monitors/converters, which is that it allows them to produce the best quality audio possible.
It doesn't matter that people listen on earbuds on public transport, the point is to make the best choices possible so that it sounds the best it can under ideal conditions.
But it has to be a total solution, without the room and monitors then high end converters do not help.
(Plus microphones, preamps, perhaps analogue outboard)
It does matter though, but the difference between high end monitors and low end monitors is much greater than high/low end converters.
It's also why stole the room in my house with the best ratio etc to the annoyance of my wife
Si
https://www.presonus.com/products/audiobox-ione
Obviously only one input, but you did say “basic”.
The bundled software is - I believe - all downloadable FoC.
That said, it soon becomes clear that - aside from a few dBs here and there and some interfaces' inability to drive high impedance headphones - there's not a lot in it for the home/hobbyist musician.
For me, driver support and latency are the issues, so I pay a bit extra for RME.
I think in the case of Presonus their interfaces come with a version of Studio One Artist which is otherwise $99
It's not that big of a deal as I've tried the trial of Presonus and I don't like it as much as FL or Ableton, but it's always nice to have it to play with.
How mad is that. Buy a hardware interface for £80, and get an £80 s/w package for free - well, for the time of creating an account and downloading the software. I'd assumed that it was the free (Prime) version rather than than intermediate (Artist) version that was bundled.
I've never used this one - only used/registered its slightly bigger brother.
The bundled software with interfaces can be really significant.
For example if you want Ableton you can either pay £70 for Intro, or get it free with almost every soundcard or MIDI controller. That software isn't all that useful as it's quite limited, but once you have Intro you can get Standard for £260 rather than £320.
It basically means you can get free hardware if you were intending to buy the software anyway.
The same is true for FL Studio with the Akai Fire.
