Best way to clean rusty hardware and screws?
Got a new (used) guitar this week that needs some tlc. Rusty screws, pickup polepieces and a bit on the bridge.
What's best/easiest to clean to bring these back to life? WD40?
  • hywelghywelg Frets: 4327
    Phosphoric acid. Readily available.
  • SporkySporky Frets: 30206
    Malt vinegar works too (and you may well have some around the house), but given the choice hywelg's suggestion is betterer.
  • DiscoStuDiscoStu Frets: 5737
    As it happens I tried soaking them all in white vinegar cos I found a bottle in the cupboard. A bit of scrubbing with an old toothbrush and everything is looking far better now.
    For future reference is phosphoric acid available in shops or is it an internet job?
  • longjawlongjaw Frets: 428
    I soak screws in plenty of WD40 for a day or so first, certainly gets rid of all the muck!
  • matt_seftonmatt_sefton Frets: 1087
    Backwards relicing! A whole new concept ;-)
  • BillDLBillDL Frets: 9013
    Good old Coca Cola and some other fizzy drinks contain phosphoric acid but, although it will make 2p coins all shiny and new looking (just as the vinegar in tomato sauce would do), it isn't a high enough concentration to remove rust unless you leave the parts submerged for a long time and keep agitating the container.
    Most industrial descaling solutions are dual purpose in that they contain enough phosphoric acid to remove rust.  One thing you might already have kicking around the house if you drive a car is alloy wheel cleaner.  If you do have any, look at the label.  A lot of them contain phosphoric acid and are usually strong enough to break down rust.  A lot of grout, concrete and slab cleaners contain phosphoric acid - go to B&Q and start reading the labels.  If you have a tool hire company nearby that leases out scaffolding pop in and ask them what they use to de-rust the bolts on their couplings.
    I don't think you'll find phosphoric acid in any shops, online there's plenty of options. 80% should do the job.
    I have alloy cleaner and patio cleaner in the shed. Never thought about those.
  • inewhaminewham Frets: 181
    Citric acid also removes rust
    Ian
