Yes, the switch can pass through the widest part of the F hole on a Hamer XT Series ES-alike …
BUT
… it is necessary to tilt the switch body and rotate it to persuade it through.
This will be almost impossible once you have two 4-con + shield humbuckers connected.
The modern PCB type won't but the old ones should.
Tempted just to drill a hole for a mini DPDT switch...
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
Thus, the switch body can only be threaded through the F-hole in one orientation. Namely, with one of its rounded ends in first and its flat edges parallel with the edges of aperture.
Very much a ship in a bottle project.
