Whatever's going in the front of your amp will definitely be coming out of the XLR (so that's the first half of your pedalboard).
You probably want to be using the XLR into your interface because it's emulated (otherwise you'd need to a plugin to do the job within your DAW).
Are you saying that the effects in the loop aren't present in the XLR signal?
There's an argument for not recording 'wet', e.g. delay/reverb: edits are cleaner without and it can be added later in the DAW (where there are lots of other benefits).
