Obviously, this doesn't help much if you want custom off-centre notching.
I've got the non locking versions of both (facepalm)
I've put the locking bridge, locking studs, and tailpiece on a LP and a 335 now...I did start out with the normal bridge though
I also put the locking studs for a wrapover bridge on an SG and that was a good move too.
Yes, these are just 'starter slots' and need to be filed out to suit your string gauge
As mentioned already, the little dips in the ABR saddles are just for starters. My preference is for unslotted. That way, any minor string alignment issues can be compensated for by where I choose to make each slot.
YMMV
