If the OCP P90s have two-conductor + shield output cable, you could have phase reversal via a push-pull pot. (Not sure how much use out-of-phase would be.) Series/parallel interconnection is also possible but this usually sounds muddy.
If the OCP P90s sound loud and dark, you could have a push-pull pot activate a Bass Cut switch à la Fender Jaguar.
Holes are already enlarged so I can fit imperial size pots in there if I need to.
I don't bother with treble bypass. I just use a pile of gain.
