But I have to say - why?
As long as the cable is disconnected when it's not being played the battery will last for at least a year. Just do an annual swap at the same time as changing strings.
EMG specs for the pre made scratchplates show battery life of 1000-1500 hours for pickups with just normal volume and tone controls, and still 200-300 hours when there are the active tone controls like the SPC and EXG.
That's a lot of time for being actually plugged in and in use. Even with the current heavy Gilmore set that's about 4 hours a week every single week for a year. If you haven't got the SPC and EXG then it's 20 hours a week or more depending on whether you have 2 or 3 pickups in it.
I have a guitar set up with the universal pack on the control cavity backplate and I use it for either EMGs or Fluences depending on what I need it to do at that time.
if you wanted to recharge an internal battery then you could put a connector for the positive terminal in the trem spring cavity and use the jack socket for the Neg … But it just isn’t worth it
