gigrig power supply system
allicioallicio Frets: 221
Just been looking at the gigrig power supply system. Just wondering if anybody else is using it? Is there a difference between there generator and something like the visual sound one spot?
Ive got a one spot already and was just wondering if it would work with one of there distributes and isolators?
  • dindudedindude Frets: 8575
    I used a distributor with a diago powerstation for a while and with no issue, in fact it worked a treat. Can't see an issue using it with a one spot.
  • spacecadetspacecadet Frets: 671
    I use the generator and various adapters on my main board and b board but use a one spot and distributors on my mini boards. Works fine. The advantage you get with the generator is the added power handling. 5000ma can power a lot. If you have a lot of eventide, strymon etc then the adapters can bump the price up a lot but it's worth it. You can go anywhere in the world and power your board with a single iec cable. Brilliant. And it's quiet.
  • GIJoeGIJoe Frets: 213
    I purchased this exact setup off @dindude - brilliant.  I have since added lots more adapters etc.  It's not cheap, but bits do appear second hand occasionally.  I keep meaning to upgrade to the generator, as it has more current, but have not found any bargains on ebay!
    "Nobody is really researching robot jokes"
  • allicioallicio Frets: 221
    Cheers chaps! Just ordered a distributer, isolator and a timelord thingy, thanks again
  • hywelghywelg Frets: 4316
    I'm always looking on eBay for GigRig power bits and bobs. I have two Generators and a distributor, a couple of my own homemade distributors, a couple of Eventide adaptors one of which has been adapted to power a TC Nova Reverb.
    The difference with other supplies is that others do have a limit to the power output per socket, whereas the GigRig stuff, you can keep adding new pedals without worrying if you've enough power, just keep daisy chaining distributors. I do need an isolator as I have an EHX B9 which is noisy. Just haven't got around to ordering one yet.
    Cheers c, looked on eBay but didn't see anything second hand. Will certainly keep an eye out though!
