Sorry in advance for the wall of text Im on an ipad.
Hi Guys,
Ive noticed theres a few car enthusiasts on here and was wondering if anyone has some mini experience?
Ive got a 52 plate MCS owned from new (now ~140k miles) that has started giving me a bit of grief since Ive brought it back on the road after a 2 year layup.
Its passed MOT recently and generally runs fine, the problem is that on start up it idles fine for about 30-60 seconds then the idle gets really lumpy/rough. It saves itself from stalling and theres no power if driven while its doing this. It resolves itself after another 30-60 seconds or if I switch it off then back on again.
I had this problem once before and called the RAC out (before the layup). The guy cleaned the throttle body and all was well. Obd code p1688 which points at MAF sensor. Ive cleaned the throttlebody today and the MAF sensor on the front by the intercooler. I couldnt release the allen bolt on the other MAF sensor so left that alone. The idle was still rough after this and it did the same when I started it 30mins later. Took it for a 50mile spin (twisty bits and dual carriageway) and it ran fine. I'm thinking of getting an obd reader/resetter (can anyone recommend one?) to see what happens when its doing this. To me it points to a problem with fuel/air but Im no mechanic and this thing is nothing like the minis of old which I used to mess around with in my youth.
Any help/comments are greatly fully receieved.
http://www.mini2.com/forum/first-generation-faults-fixes/71424-cooper-s-rough-idle-possible-fix.html
I'd say it was a sensor of some sort if it was laid up for a while. Might be air flow sensor. Oxygen sensor?
Your crank sensor is basically your modern day distributor apparently, so that will affect the timing and cause it to run rough.
Sounds like a stepper motor (Idle air valve) which is part of the throttle body.
Although TDC(crank) sensors, cam sensors (if fitted), coil or blocked fuel filters can all give similar symptoms.
Try running a good fuel system cleaner through the system first, as this might just be a slightly blocked injector.
Try tapping the throttle body with a small hammer when it does this. Should indicate if the problem is in there.
I'm not too familiar with this specific car, I'm guessing it's a "fly by wire" so no throttle cable, so it's possibly a throttle position switch.
Sounds more like a slight fueling issue, rather than anything more serious.
I've used Wynns, Fortron or Forte for cleaners, and found them all good.
However, you would need to find a Classic Mini owner dim enough to do the swap...
