Those 50/watt acoustic guitar vocal amps
midiman1962midiman1962 Frets: 102
There are a few of these around where you can stick a mic in one channel and acoustic guitar in another. Having dragged an hk Lucas into a micro pub last weekend,thinking that one of these might be a good solution? The Marshall as50 seems to be the predominant amp here , though I see Behringer have their version acx900 which seems to have a few more features.
anyone use either of these or have any other options? Tia
  • TheBigDipperTheBigDipper Frets: 4775
    Following….
  • ICBMICBM Frets: 72322
    AER Compact 60
    Acus One 6T
    Fishman Loudbox Mini
    All these are smaller and sound better than the Marshall in my opinion - though more expensive (the first two especially).
  • greejngreejn Frets: 127
    AER Compact 60, or Schertler David. I prefer the latter, but both great amps that project really well...and my favourite trick is to send to a mackie PA speaker as well.
  • SnagsSnags Frets: 5369
    I've got a Loudbox Mini. It won't replace a PA for a big/noisy place, but it will give you a good lift for a small pub/café situation. I haven't checked it recently but my recollection is that you can get the guitar significantly louder than the vocal through it, although that might be as much to do with the register of my voice as anything else.
  • maltingsaudiomaltingsaudio Frets: 3127
    Done loads of gigs with that kind of set up using my aer https://fb.watch/cRjd_XEy0O/
    www.maltingsaudio.co.uk
  • BenSirAmosBenSirAmos Frets: 410
    edited May 2022
    AER Compact 60 for me too. Fantastic sound - perfect for my vocals and harp and a guitar. Also put a mic on the congas in the absence of a drum machine that will give me a decent bass drum sound (but that's another thread).
    And when I do use my pa (which is rare now) I use the AER as a personal monitor.
  • SupportactSupportact Frets: 953
    The Marshall one is ok, but the ones mentioned above made by AER, Fishman, Schertler in my view sound better. Not tried the Acus one.
  • StratavariousStratavarious Frets: 3671
    I used the Marshall AS in a trio years ago for loads of gigs.  Better sounding products today but it was an easy load in!
     Does the job but compared with a modest PA, they can sound quite boxy and only good in small spaces.  Get a mini mixer and a couple of 300w or so powered mains. Yamaha do an all in one that clips together to roll in.
  • p90foolp90fool Frets: 31589
    The Marshall AS100 is way better than the 50, not just louder.
    The Fishman Loudbox is good too.
    I think that’s exactly the amount of faff and set-up space the OP is trying to avoid :). For a really small bar, a single-box amp is much more convenient.
    I’ve got the Acus One at the moment, largely because it was cheaper than the AER and the mic channel sounded better with vocals. It’s much better than the Marshall AS (I had the original one, the AS-80R). Both it and the AER are small enough to sit on a bar stool, so you don’t even need to worry about a stand.
  • BillDLBillDL Frets: 7212
    edited May 2022
    If you are on a restricted budget you might also consider Laney acoustic amps.  I have the 30 watt 2 x 6.5" version of their budget line of three acoustic amps (LA30D) that is surprisingly good for the price and would probably do a quiet small pub lounge bar, but they also do 60 watt ones that are still very affordable and I think they are easily as good as the Marshall AS amps:
    https://www.gear4music.com/Guitar-and-Bass/Laney-A-FRESCO-2-Acoustic-Combo/2VDX (1 x 8" dual cone)
    Don't discount the Roland "AC" range either, but they are more expensive than the Laney amps.
    Good reminder, I'd forgotten that - there was a Laney A1 (now replaced with the 'Plus' version I think) in the shop I work for not long ago, it sounded very good.
  • midiman1962midiman1962 Frets: 102
    I do have 2 mobile Roland ac amps which I use for outside busking but at 5 watts you are “on the edge” in terms of being loud enough - got away with it on non windy days outside the co-op where the building formed an L shaped cove to play from. I had noticed the Laney so good to know this is worth further investigation- thanks
    @keefy had a Laney A1+ for sale in the classifieds section here a while back.  It went for an absolute steal.  I would have bought it but I had just bought my 30W one.  I think the A1+ is now discontinued though.
  • KeefyKeefy Frets: 2286
    Yep, went to @danishbacon.
  • danishbacondanishbacon Frets: 2695
    It’s a superb amp, it was used for a solo classic gig last weekend by a friend who came back with only praise! He otherwise used a high end Bose PA system
  • steviebee74steviebee74 Frets: 33
    edited May 2022
    I often use a Roland AC60 with a separate 10” Tanglewood T6 Sub. The beauty of this rig is that both pieces have a socket for a standard pole so I can sit the amp well above the sub and get plenty of spread. I don’t sing but work a female vocalist and we’re more than happy with this for smaller rooms. The amp has separate channels for guitar and mic and volume wise, it’s easily able to cope with 50/60 people.
  • TJT1979TJT1979 Frets: 188
    edited June 2022
    I highly recommend the Blackstar Sonnet. I got the 120w model due to extra flexibility (phantom power in both channels, individual line outs per channel or DI mix, both with post/pre switches, etc)
    Honestly I was really surprised how good this sounds. I’ve only used it in very small venues so I haven’t got it past probably 10 o clock on the volume.
    I’ve used it as a monitor sending signal to a PA, and also as the only reinforcement.
    The only things I’d change are that the bass ports should be on the front rather than pointing backwards, and I’d like a Clip indicator when setting the input gain for each channel.
    Edit: I have a dynamic mic straight in, and the guitar goes in via a Baggs Session DI which uses phantom. The amp sounds great without the Baggs but I already had it, and it’s useful as a mute switch.
  • joeWjoeW Frets: 462
    Henriksen the Bud has 2 independent channels which is good for guitar and vocals. Definitely more jazz focused and on the pricey side, but they are super light and very loud
  • JCA2550JCA2550 Frets: 439
    I am happy with the Fishman Loudbox Mini, but will also vouch for the AER Compact 60 and Blackstar Sonnet. The Marshall AS series are simply outclassed by them. If I was starting again, I'd definitely go for the Sonnet.
