I haven't listened to the other demo, but I suspect the same is true as with a lot of gear, and that the player can make a lot of difference to how it comes over.
I have the original non-EQ version - it's very good. It's the only overdrive I've ever tried which doesn't have that typical irritating separation of the clean and dirty sounds as the signal decays back to clean. It's not actually especially high-gain, cleans up well with playing dynamics and is quite midrangy unless you crank up the bass and treble - I run both nearly full up.
It is theoretically 'Tube Screamer based' - at least, it uses the same type of clipping circuit - but doesn't sound anything like one.
I'd say different, but in a good way. It's smoother than the OCD and less harsh too. like ICBM says it's mostly a tubescreamer esque pedal, I owned the non eq version too and i can honestly say the eq version is better. Mesa pedals are built like tanks, sound great and seemingly versatile but..... A bit spendy
I've got the Grid Slammer.
It's a better Tube Screamer than any TS I have ever heard or played with. Very happy with it indeed. It's certainly a keeper.
