Why does my Bigsby arm feel spongy?
EvanEvan Frets: 326
I’ve fitted a new B5 to my Tele partscaster and amongst the many issues I’m sorting out one by one, is the fact that the arm has a bit of sponginess/play in the first few millimetres of its travel, before it properly engages.
Any help appreciated.
  • stickyfiddlestickyfiddle Frets: 26987
    edited May 2022
    I would guess a little bit of play where the arm attaches to the main assembly. If it's that, you can tighten the nut that holds it to the main assembly (you may need to slacken strings and remove the spring to get to it)
    https://guitar.com/guides/diy-workshop/20-gretsch-top-tips/
  • EvanEvan Frets: 326
    I did tighten that a couple of days ago and I thought it improved things. Would it loosen again so quickly?
  • digitalkettledigitalkettle Frets: 3244
    Is this your first Bigsby? (seem to recall that from one of your other threads)
     What spring do you have? Stock or one of the softer third party ones?
     Is there a nylon washer underneath the spring? Try removing it…replace with coin or metal washer to restore/improve arm height.
    Yes, I’m a Bigsby novice. I’ve got the stock Bigsby spring in at the moment with the nylon washer. I also have the Reverend soft touch spring, which I had in there until yesterday, but I’m not sure I like it.
    I’ll try a different washer as you suggest and also check that the arm isn’t getting loose again.
    Anyway, thanks, I appreciate you giving me the benefit of your experience.
  • BodBod Frets: 1299
    If it is working loose, you can get thread lock to keep it in place - https://www.ebay.co.uk/itm/384008445492
    Even if it isn't working loose, it's a handy addition to anybody's toolkit :)
    Excellent idea - thanks.
    Actually, I’ve just watched a YouTube video of a bloke (name of Nathan Sink) talking about this same issue and it seems to be down to the stock spring. He swapped it for a Reverend and that seemed to cure it.
    So it’s back in with the Reverend spring today then.
  • nonesuchnonesuch Frets: 308
    I've got a Reverend guitar that's been in for a bit of work on the nut because of tuning issues, and the guy reckons the Bigsby isn't returning to pitch because of the Reverend soft spring. He's swapped it over for a stiffer one, so I'll see what it's like when I collect it tomorrow.
    I had a similar situation...the Rev spring was more responsive...the stock spring was more positive. I believe it should 'break-in' a bit over time.
    Important point: in general, Bigsby vibrato response is a more gentle experience than with other systems...that doesn't mean you can't be extreme with it...but it's a different beast.
    I’ve put the Reverend one back in and the “sponginess” has disappeared, the arm sits higher (better) and it feels better. I’ve also put in a stiffer washer.
    I hope that tech is wrong about the Reverend causing tuning issues.
  • impmannimpmann Frets: 12665
    It won't be the softer spring causing return to pitch issues...
    Nice one...if it's working, it's working ;)
    The Reverend might not have been helping when combined with other factors: badly cut nut, non-straight string pull (should be okay on a Tele!), break angle over the saddles, etc.
    Thanks for  all the help you lot.
    What would we do without all these irritating problems to solve?
  • TheMarlinTheMarlin Frets: 7860
    Take the Bigsby arm nut to a hardware store and get a nylock replacment. Nip it up to where you like it, it won’t move again.
    I hate any play in a Bigsby arm, ruins the experience for me. I like them nipped up nice and tight, and the arm staying exactly where I want it. Rigid.
    I have a beautiful Jazzmaster, really loved it. Pickups were fab, neck was ace, played beautifully, was almost perfect.  I had to sell it because of the tremolo. There was a fraction of a millimetre of travel in the arm before it performed any kind of wiggle.  Then there was a slick click where the arm engaged. That tiny amount of slack and the click I could feel ruined the whole guitar for me.
    I’m weird. I know.
    I have a Jazzblaster now, but came to me minus the arm.  And no arm I’ve found fits the hole.  Having a trem I can’t use is almost as infuriating as having one that clicks.
  • ICBMICBM Frets: 72324
    It can if it’s like the one in the pic. The nut should be a self-locking type, either a Nylock or a split-crown metal one, or there should be two nuts do you can lock them against each other.
    I do find soft springs cause more tuning problems too, although it’s not the main factor. I’ve never liked them and don’t understand the attraction… I’ve made replacements from cut-down air rifle springs in the past - stiffer than any standard Bigsby spring, and much more positive in feel and return to pitch.
    It’s that bit of very little happening for the first few millimetres of arm travel that bothered me, not the stiffness so much. Point taken about the nut.
    I’m weird. I know.
    I can recommend a therapist for that.
    I’m weird. I know.
    Thats where a Staytrem arm and collet comes in for the offset trem system - it solves that issue once and for all.
