Call me with your best price.
There was a small separation between pick surfaces. In use it did work for strumming, as each string got picked several times on each pass. Don't know about picking though.
It was a bit unwieldy due to the thickness, about that of a usb flash drive.
I made one from a few Jim Dunlop's and araldite, it's probably lying about somewhere after 5 mins use...!
I bet someone on here still has one though.
The tik-tok one looks to be a single pick with 5 studs on it, so similar (but better) design. Certainly sounded as though it worked. Another option for occasional sound variation.
Well spotted Stu, you should keep suppin'!
A somewhat similar thing is the old shark fin pick with one serrated edge. https://www.guitarstringsonline.com.au/jim-dunlop-tortex-fins-blue-1-0mm-guitar-picks-6-pack/
These work great for grungy chunka-chunka rhythm playing but - again - you can revert to a standard sound at any time just by changing your grip.
I found it hard to use cos the bit you hold was very thick, about 8mm
EDIT - here ya go - the Dunlop "Strummer"
@Tannin yes, I'd forgotten about the shark fins, I have a few lying around, they're interesting.
I particularly like BillDL effort though. Not sure how it would sound.....
This is the roundup of my winners as they suit whatever little style i have best.
Everyone will have their own preferences of course.
(Finally cracked the image posting!)
Clockwise from the top: Fred Kelly Speed Pick; Herco Flat/Thumbpick; Sharkfin as mentioned by @Tannin (I'd forgotton about those!); Herco Gold 50.
The Fred Kelly I got mailed from Eagle Music in Huddersfield, they were the only UK place I found selling them at the time - I prefer not to buy from Fleabay if possible. The Herco flat/thumbpick came from there too. (i have no connection to the shop, in fact a few handfuls of picks are all I've ever bought there).
The flat/thumbpick is good for picking and then strumming a chorus.
The Fred Kelly looks a bit fragile but is quite robust, my favourite for picking (which is most of the time), but didn't feel right for strumming.
The Herco Gold is my go-to flat pick.
The sharkfin is a bit of a novelty, rarely gets used.
I have several speedpicks (they come in a variety of thickness and colour. I have two sharkfin picks. And that FK one you got from Eagle, that must be a Bumblebee
EDIT: Oh an Herco. FK makes an almost identical one known as Bumblebee.
