Picks
JfingersJfingers Frets: 366
Who here plays with a pick?
I hadn't played with one for donkeys years until I found one in a jar with lots of other stuff.
It was a Jim Dunlop point six mm, grey. I used to use them a lot.
I found it immediately changed my style (I mainly play on an acoustic these days)
Much more strumming and a lot less thumb...
Sorry if it's not off topic enough.
  • BrioBrio Frets: 1831
    Me. 80% of the time.
    I usually fingerpick but when I want to thrash the strings I'll use a Dunlop Stubby.
  • NiteflyNitefly Frets: 4916
    For electric guitar, I use Dunlop Tortex yellow (0.73 mm).
    For acoustic, it depends what I'm playing - same pick for strumming.
  • bertiebertie Frets: 13569
    dont worry, hopefully it will soon pass
  • LestratcasterLestratcaster Frets: 1087
    I mostly if not all the time play with a pick, very rarely do I do fingerstyle or play with my fingers. I use the tortex 0.73mm for acoustic and the 0.88mm for electrics.
  • PolarityManPolarityMan Frets: 7287
    Black fangs mofos
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • HAL9000HAL9000 Frets: 9663
    I never play with a pick. I find I’ve got more control using my fingers.
  • BarneyBarney Frets: 616
    I play with pick and fingers ....or just pick depending on what sound I want
  • RolandRoland Frets: 8704
    For years I played with just fingers. Still do when the music merits it, but most of the the songs I’m playing at the moment need a pick.
  • KilgoreKilgore Frets: 8600
    Fingers only. There's something about the tactile sensation of your fingers on the strings. Apart from which, I'm just rubbish with a pick.
  • guitarjack66guitarjack66 Frets: 1851
    Picks mostly. I still like to practice using my fingers too.
  • MellishMellish Frets: 947
    I always use a pick and my guitar is electro-acoustic.
    It's a Dunlop Tortex red pick. Not that thick...point 50mm? :)
  • Open_GOpen_G Frets: 146
    For live stuff, I'll tend to just be chord bashing, and bits of lead, so will use a pick.
    At home, almost always fingers, for picking, lead, chordbashing et al.
  • PALPAL Frets: 539
    What ever the song needs.
  • TanninTannin Frets: 5446
    I never, ever learned to get a good consistent tone with a pick,  and my timing was questionable. No-one ever taught me how to hold one and by the time I learned the proper way to do it it was way too late to change. So I sucked. The only instrument I was really any good at was bass, and I played bass with my fingers.
    Sometimes I'd try to learn to play guitar with my fingers, but my nails are naturally weak and it always ended up in blood and mess. Back to picks.
    Then I went to a nail salon and asked for an artificial nail, started playing with one finger and thumb (same way I used to play bass). I got lots better. I graduated to two fingers and thumb, tried all four, and have settled down to using three fingers (nail and/or flesh, mix and match) and thumb (just a pick-shaped callous on the side of it).
    I keep picks around for visitors to use. Every three or four months I try playing with one, throw it down in disgust and go back to bare fingers after a couple of minutes.
    I'm not going back.
    I liked the look of those Dunlop jazz picks,both red and green,but when I bought them I found them to be too small. I prefer playing using the rounded side of the pick so would like to find a larger teardrop style pick plus I'd like a larger pick,in diameter not thickness,as I enjoy playing with more of the pick sticking out of my fingers than is considered 'orthodox.' I'm still trying to find more of a 'perfect' choice than the many I have already tried.
  • flying_pieflying_pie Frets: 1816
    Dunlop also make a Tortex TIII pick that is the same size as a regular Dunlop but with the Jazz teardrop pointed tip. I love them and use them 99% off the time for my playing
    Thanks. Will have a look at them.
  • BillDLBillDL Frets: 7222
    I've had about half a dozen IronGear 1mm Delrin picks lying around from having bought IronGear pickups from Axetec over the last few years.  I knew immediately that they were far too thick and inflexible for my liking so I've never used them.  I tend to use pearloid picks in 0.7 and 0.9mm and I like the slight flex even on the 0.9mm ones.  About half an hour ago through sheer coincidence I looked at the IronGear one on my desk and decided to sand it down into a gradual and even taper from about 1/4 of the way down to the tip that is now about 0.4mm.  It gives a very slight flex, but only on the last 1/4 of the pick at the tip, while still having a stiff, reasonably thick, and satin feel up at the wide end to grip on.  I really like this feel and I'm going to do the same for the other thick Delrin ones I have lying around while I look around to see if I can buy picks like this.
  • mgawmgaw Frets: 5262
    Blue chip picks for me.  Tried most of the others and for tone and speed I haven’t found better ime
