Looking like I'll soon be swapping my Mini Jubilee combo for a mates head version which I've wanted to do for a while, and now find myself looking for a decent but affordable 2x12 cab. Been thinking of a vertical one for being able to hear myself better on smaller stages but does it actually make that much difference, or could I just get a horizontal 1936V/similar and put it on its end?
I was looking at the Harley Benton G212 with V30s, but not sure on the build quality and the tolex looks a bit cheap and nasty. Is it like that in person or does it actually look ok? Anything else to look at that I'm missing? I was going to get the matching Marshall 2536A but it's a bit out of my ideal price range at the minute. Zilla are probably a bit much for me as well at the minute unless I get lucky on a used one.
My experience is that a 4x12 gets bottom end just by virtue of the amount of air enclosed and the dimensions giving good resonance.
With a 2x12 you don't get that so much, so the low end resonance comes from the cab sides, baffle and back. I think the construction can swing it one way or the other a lot more. Ranging from something like a Zilla*, which in my experience (I've had 4 different ones over the years) tend to be more resonant, to something less resonant like an Orange or the least resonant cab I ever used, a front loaded Framus.
If you go for a non resonant cab you need an amp and speakers that can push the bottom end without help, or it sounds stiff and thin.
Honestly if you look on eBay cabs are pretty cheap at the moment.
*the most resonant cab was a Zilla Fatboy, where the combo of oversized cab with resonant wood made it feel like my sound was wallowing in low end. Really that cab needed something with a lot of low end control/tightness and I didn't have that.
Vertical vs horizontal - my opinion is horizontal looks better, vertical does make it easier to hear at head height it it's an angled baffle. Vertical looks shit, though, unless the cab is wider than the head.
Bandcamp
Spotify, Apple et al
And yes, vertical cabinets are definitely better almost regardless of stage size - it's basic physics, they have better side-to-side dispersion (counterintuitively!) as well as lifting the top speaker up to where you can hear it better.
On a related note to the rest of the post, I've found that my Zilla 4x10 (sort of derived from the small vintage) has a kind of loose, wobbly, enveloping low end, and I've always put at least part of that down to the 12mm construction. I've got a modern 2x12 with Fanes AXAs, and that's a lot more solid in the low end, not more bass, but just everything holds together better.
Depending on where you are, there are several options available for secondhand 2x12 cabs in the range of £300 and each of these would be a really good choice.
If you weren't too fussy, any of these, four additional feet and the ability to close your eyes when setting up so you don't witness the horror that is the T of amp head bigger than cab...
Also the Studio Jubilee head is the same width as a vertical 2x12 so no worries with any ugly T shape overhang!
It’s just wide enough in vertical mode to sit a Blackstar Series One head on top, I don’t stress about the overhang, it’s better ergonomically when tweaking controls, fits into a crowded stage area better, and (on stage at least) sounds about a thousand times better…
I find a 2x12 put vertically is much more user friendly in terms of projection and hearing yourself, but agree with others on the amp being wider than the cab being a big no no.
I`ve also put a horizontal 2x12 on a beer crate and that also works fine for wider heads. 2 crates if you`re feeling flush! I used to prefer 4x12s being on the floor rather than castors for the bass response, but tbh having the amp off the ground doesn`t seem to bother me that much any more.
I like quite light weight ones with a bit of "movement". A bit "lively".
Some combinations can be surprisingly good, even with one ‘less good’ speaker. I recently discovered that a G12H-30 and a G12L-35 - which really isn’t very good, on its own - sound great together.
Has anyone tried the EHX 212 vertical cab? Possibly better construction as it's ply, and its £300 at GAK.
https://shop.ehx.com/item/2x12cab/
