Ebony bridge pins should also help to tame it
And sorry to disappoint but I’m just not a bridge pin, sound difference believer. Find it all a bit foo to be honest, I have done it before but found it made no discernible difference.
Think what I was trying to get at was I tend to find PBs exacerbate a bright guitar making them sound a little clinical and overbearing while 80/20 do settle down after not much playing in and seem to have a quite neutral response.
I’m in no rush to swap the strings out, it sounds bloody marvellous as is so will continue with the mystery strings that are on it now.
2004 Yamaha LL-500
1995 Yamaha LA-8
You *should* do what works for you
The removal of the old 80/20s revealed the redundant piezo USP which I've left in place for now as to remove will require a new saddle making.
The new strings are quite nice to be fair, it's a long time since I've experienced the bright, crisp and fizzy tones of fresh PBs and I'm liking what I'm hearing so far. Will keep them on long enough for them to properly settle then I'll revaluate.
It has confirmed to me though that this particular LA-8 is a goodun'.
2004 Yamaha LL-500
1995 Yamaha LA-8
2004 Yamaha LL-500
1995 Yamaha LA-8
