Trick Bigfoot Pro1v Double Bass Drum Pedal £300 ono
Don't know if there is much interest in drum accoutrements on here but I'm looking to shift these on as they've been idle in my shed for a few years due to my preference for Axis Longboards.
Direct drive double pedal with compression springs, bit dusty due to hanging out in aforementioned shed, probably want some fresh velcro on the bottom so the slave pedal doesn't move about.
Currently retailing at 899 at Andertons, grab a bargain if you don't mind signs of use.
