Tonerider AlNiCo II Set HSS Pickups £70
These are pretty much brand new (though I had soldered them into a HSS Strat) and they have their original boxes
Zebra / Cream / Cream
- AC2 F-Spaced Humbucker 8.3kΩ
- TRS4 AlNiCo 2 neck and middle pickups (6.2kΩ & 6.1kΩ)
10 potentiometers £25
Rosewood veneer pickguard
Kinman Hank Marvin noiseless set
Cream pickup covers and knobs
CTS pots
7-sound Gilmour mod (brings in the neck pickup) on a push-push Second tone control
Kinman treble bleed / bypass mod
https://i.imgur.com/8ywZQeD.jpg
D'Addario EXP115 11-49 NY Steel strings (set of three) £15
Two Ibanez 2502N switches
For use with two humbuckers - Ibanez wiring
One used £7
The other new £10
Les Paul Metal Jack plate & Pickguard bracket £5
Plectrums
mix and match - 35p each.
Dunlop Ultex sharp 2.0mm (I have 24 of these)
Dunlop Tortex Purple 1.14mm (and pretty much identical Fender 1.14mm thickness) (48)
Gibson Aged / Relic Les Paul Strap Buttons £8
https://i.imgur.com/QsLys4M.jpg
Straps
RotoSound Superwound Strap £6
5mm tremolo arm (free)
Ibanez Cosmo Black Metal Knob (free)
- Nickel plated Hardtail Bridge with bent steel saddles (54 mm spacing)
- Recessed String Ferrules (Bridge earth / ground wire installed)
- Nickel Jack Plate
https://i.imgur.com/eSr8Rig.jpg
Fender F Neck Plate £8
Chrome Neck Plate (with screws) £3
Nickel plated vintage tuner 8mm bushings £3
https://i.imgur.com/91Bxh6A.jpg
Dunlop Glass Slide £4
Gotoh aged strap buttons £5
Black pearl pickguard + back plate
Bridge: AC2 F-spaced zebra humbucker
Neck and Middle: cream coloured TRS4 Alnico 2 single coils
Super-switch
Humbucker coil tapped in position 2
Noise cancelling in positions 1, 2 and 4
510kΩ resistors for single coil pickups so they see 250KΩ (while the humbucker sees 500KΩ)
47nf capacitor
https://i.imgur.com/W9ksFT8.jpg
1-11/16” nut (42.85mm)
10” radius
https://i.imgur.com/QQqqHdF.jpg
Tonerider AlNiCo II Set HSS Zebra / Cream Pickups added
Eqd Speaker Cranker clone
