I'm planning a build for my first HSH guitar. Three piece through body laminate of 1x maple + 2x mahogany, ebony fingerboard, lightweight sapele wings and quilted heart/sapwood golden camphor top. Styles of music it'll be used for range from jazzy vibe all the way to pop rock. So ideally 80's classic rock in the bridge, stratty quack in positions 2 and 4, tele-ish in position 3 and jazzy in position 5. I understand there will always be an element of compromise in this kind of set up but the greatest challenge is predicting how successful positions 2 and 4 will be while many manufacturers don't publish impedance or resistance info on each coil in their humbuckers.
I don't use the middle pickup much either so will wire things up so the middle position is neck and bridge together using a DiMarzio EP1112 5 way selector and a push pull vol for splitting the humbuckers. Should be a fairly uncomplicated system to use with no options that I won't actually use (which is why I shied away from a Freeway superswitch and similar).
Pickup wise I've been looking at:
DiMarzio Tone Zone + FS-1 RWRP+ PAF Pro
Suhr SSV neck, ML Standard middle, SSH+
bridge
Dimarzio Dual
Sound + True Velvet RWRP + PAF 36th Ann
Are there any other recommendations or approaches to achieve the options I've mentioned above? I'd be grateful for experience only, please. There's already a lot of advice out there on what people think *might* work.
My PRS Swamp Ash Special has exactly this, with a Duncan Vintage Rails in the middle - normally, literally the worst 'decent' Strat pickup I've ever heard - but in combination with the humbuckers, it sounds really very Stratty... even with PRS Dragon II pickups. The best 'Strat' sounds are actually with the neck split but the bridge *not* split, amazingly - these are the stock PRS settings. (I've added an extra switch to split the humbuckers separately from adding the middle pickup, so I have been able to directly compare all the options.)
If you don't want to do that, but want to split both humbuckers in the 2 and 4 positions, you need to look for a bridge humbucker which has about double the output of the middle - this one is harder to get right than the neck, which seems to work as well with a lower-output pickup - and ideally split both humbuckers to the coil nearer the neck, and if that's not practical then both to the coil nearest the middle pickup.
Does that help at all, or even make sense?
Oil City Scrapyard Dog Plus
Oil City Stonetone (overwound version)
Oil City Nightfighter 4
Both humbuckers are covered. Steve Vai style circuit with automated coil splittage to the stud coils for positions 2 and 4.
Host guitar - Heartfield Talon 3, a 22-fret Ibanez RG wannabe.
Thanks! Did you buy them as a set? I may drop Oil City a line and see what suggestions they have to offer.
[This space for rent]
When my SAS belonged to a friend, he didn’t think the ‘Strat’ sounds were Stratty enough, so thinking it was the problem, he got me to replace the Vintage Rails with a proper Strat single coil - a Duncan Alnico 2 - which actually made it worse. I put the original back when I acquired it, but the key - even more surprisingly - was to replace the stock McCarty humbuckers with Dragon IIs. Totally counterintuitively, the hotter humbuckers actually sound more Stratty combined with the middle - and they aren’t out of phase, I checked!
The RWRP question probably doesn’t matter - you will get a little more hum in the 2 and 4 positions than you would with an accurately matched single coil of the right polarity to cancel with the split humbuckers, but probably still less than one of the wrong polarity, if that makes sense! The split positions in my PRS don’t hum badly even though the middle is a Rails. It also means the middle+bridge *un*split is completely hum-free, which is good.
If you have the means to experiment with these positions split and un-split before committing permanently, I would try it.
The SYD+ was in a non-standard colour scheme. This obliged me to order a brand new Nightfighter IV Neck humbucker to match.
Yes. Always better to talk to the organ grinder rather than the monkey.
IMO, these models would serve well for the neck and centre positions.
My tastes in DiMarzio bridge position humbuckers are The Breed, Crunch Lab and Illuminator.
NOTE: If your guitar is going to have a near flat fingerboard radius, a single coil pickup with "staggered" length polepiece rod magnets might not be suitable.
