Ive had expensive ones go faulty before. Recently had one that developed an odd rattle after installed and it was still there when I took it out.
Always worth testing them before you install
Instagram
It had a yellow shrink wrap.
Unfortunately they are all much the same, so its just a case of trying to see any issues before installing, and testing as you go.
I once had a fancy stew-mac one where the hexagonal allen key hole was totally round inside and out.
Instagram
I agree they do seem to be a bit of a muchness in design, looks like I'm taking pot luck again.
It’s unfortunate that happened, but it does reinforce what I’ve thought for years, that it’s baffling why most/all guitar makers (ie manufacturers, not you specifically!) don’t make the body end of the truss rod accessible via the pickup cavity.
