I've failed to finish any of the recent challenges.
Despite my best intentions and all my efforts at pissing off potential clients, retirement continues to evade me and work is, if anything, busier than ever. On the upside, it means that when it gets really cold in January, we can have the heating on. (Just for the one day).
So I'm a little wary of committing to this challenge, but without the group-incentive (and shame of failing again), I'd certainly not get anything built.
With the help of Mr
@GSPBasses who has provided the body (and neck), I'm going to try a putter-togetherer. It's a nicely weighted body, not too light, not too heavy with a normal-Graham-standard top.
A quick look through the parts-cupboard revealed a mini-HB (neck) and a stacked Tele pickup (bridge). I think I'm going to direct mount the bridge pickup, and quite probably the neck 'un too.
I also found a Graphtech Ghost acoustiphonic control board. All I'd need would be the piezo equipped saddles, so that's a possible.
Not sure on how to finish it yet. I'll round over the top edge, and probably belly-carve the back. I'll stain the top, but haven't a clue what colour/s ...
Anyways, pics as it is now, and will probably stay for the next few weeks at least.
As someone who has been building a guitar for, well I've forgotten how long, I feel your pain. I'll get it done at some point
flanging_fed “
An hour??
It's a large and disorganised cupboard!
Now I'm trying to work out the best way of getting the little piezo cables from the saddles into the control cavity.
I am still waiting to see what happens to that big lump of London Plane
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Simples. Drill a hole through the maple cap, somewhere near the centre line of the body. Hide this hole under the vibrato tailpiece of your choice.
... but falls apart at that point.
The only vibrato tailpiece I’d choose is no vibrato tailpiece!
PlanB is a HB in the bridge, with some sort of pickup surround under which the piezo wires will disappear into a maze of cavities and sub-cap tunnels.
That took a ridiculous amount of time to get done!
Yes, I could, probably should, and might even dare to ... you're not an idiot at all.
I did the template to test/check the CNC code really.
I'm thinking that, if I test all the individual "parts" of a build, I should be able to combine them all together into a complete body. The target is to be able to mix & match body shapes, carves, cavities, etc.
Mr Gibson is shaking right now ...
Im a bit envious of your CNC, however I would probably turn good wood into kindling
Also want to take 5mm off the back of the neck cavity because it's more than thick enough.
So here it is with the recesses cut, 5mm off the join area, and the carving tool out to start to blend it in ..
And here it is a few minutes later ...
Next jobs;
- fat belly carve
- sandpaper out to blend the shaping above, and the belly carve
- round over top & back edges
By which time, I might have decided on pickup configuration and hence bridge, and can then get the p'up cavities routed.It's either going to be a tappable HB in the bridge, for which I need to buy and fix a chrome cover, or a P90.
Plus I'm going to buy a set of piezo saddles to feed the Acoustaphonic kit I've had languishing in my parts cupboard for years.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Thanks @PeteC.
There are a couple of learning curves really - one is the software tool that you use to do the designing of whatever you want to cut/shape, and the other is then the application that turns the design into code that tells the cutter where to go and how deep to cut. Neither is massively steep, but it's completely new ground for me, so my main challenge has been retaining what I learn - and then don't use again for 6mths, by which time I've forgotten some part of it ...
Thanks to @GluedtoMusic and to Axesrus for excellent service.
Also got the captive nuts installed in the heel
That neck is going nowhere.
I'm going to use a couple of tappable HBs. Mini in the neck, and full size in the bridge. Plus the Graphtech Ghost saddles.
OPTION A:
OPTION B
I'm leaning towards option B. I'd then cut some small grooves into the bottom of the p'up ring for the piezo wires, or some small grooves in the top of the top.
