Anyone onto these?
https://www.gear4music.com/Guitar-and-Bass/Cort-CMV15-Combo-Amp/4NJOSpecs:
Power Outage: 15W
Rated Load Impedance: 1 Mohms
Speaker: 12” 16ohms Moollon Custom 30W
Dimensions: 470*500*230mm
Weight: 17kg
Pre-Amp Tubes: 12AX7 x 3
Power Amp: EL84 x 2
Controls: Gain, Bass, Middle, Treble, Master Volume
Input: Front - HI / LO Instrument In
Output: Back – Speaker Outs (2ohms, 8ohms, 16ohms) Ext Loop (Send / Return)
Chassis: Aluminium
Cabinet: Birch Plywood
£649...?
A quick Google doesn't reveal too many opinions or first hand experience.
It looks very well-made. There are some good photos here -
https://www.cortguitars.com/product/item.php?it_id=1607305949
In particular, if you look at this one
not only is the build quality and attention to detail very high, the resistor on the second valve socket means it's a cathode-follower, which could be the tone stack driver, in which case it's likely to be based on a Marshall 2203/4 circuit. (The resistor value appears to be 220K, which is higher than Marshall's 100K though.) Or it could possibly be the FX loop driver, unless that's solid state.
The biggest question mark is probably the speaker - just because it claims to be apparently modelled on a G12H-30 doesn't mean it sounds like one...
The 2-ohm output is a typo by the way - it's 4-ohm.
Nice to see a new amp with the controls in the right place too .
Speaker upgrade might bring it up to par if the stock speaker isn't that great right?
Different thing really (see big names with more features ) and they have well-known problems with noise too. Depends whether you want a very simple but well-made amp or a more complex one with channel switching and reverb.
For the price I assume the Fender is used too, which makes it a far safer option for resale.
Yes.
The yard is nothing but a fence, the sun just hurts my eyes...
