The plan is for a laminated through neck of beech & mahogany (what I had to hand) which was started yesterday and the body wings will hopefully be a poplar core with walnut top and bottom. I already have the poplar left over from the dismantled piano and need to source some walnut. This will hopefully end up being the thinnest build I have done, looking at between 24-28mm, should help keep the weight down and it will have one pickup with volume & tone control.
This may take a while compared to my usual builds (average time has been 6 weeks start to finish). Funds are non existent, so parts will be as and when money comes in, and in the meantime it is a case of using what I have to hand. I am planning on making a pickup for this, already done a test pickup with thicker wire stock taken from an old extractor fan which only had enough for 2000 winds (completely hand wound...), it worked well but had a very low output and would require a preamp to boost it. I may well use the test pickup in a future build with a preamp, but will need to buy some wire for this one. I may even try making a humbucker.
The through neck pieces were cut to size, squared and glued together yesterday. Then this morning I glued on the 'ears' for the headstock (lots of squeeze out), did a quick sketch of the body shape and after removing the clamps I tried it in position with the rough body shape cut out of cardboard. The shape may change, but the main purpose was to work out the upper horn positioning to end above the 12th fret location for balance.
After giving the 'ears' enough time to dry I set about cutting the headstock angle at 9 degrees.
After that I glued the cut-off to the back of the headstock to provide enough thickness across the length and then set about working out string positions based on 17mm string spacing at the bridge and a 38mm nut so that I could do the positions of the tuners and get a basic shape sketched in for the headstock.
Will get the basic headstock shape cut tomorrow morning and see what else I can do after that.
Will shape the wings a bit more once I have the walnut, planning on having the poplar show through on the edges similar to the mockingbird build.
Had a few deliveries today as well - Fretboard, double action truss rod and some walnut boards.
Obviously "hand wound" doesn't normally mean that at all, usually its closer to hand guided. Zhangbucker offers a "Pure Handwound" option, along with some claims on why this is so much better than a machine wound pickup.
Hats of to @JGTay , takes a lot of patience to get this far!
Instagram
Will make the bobbin for the second coil tomorrow and possibly get started on the winds if I have time. Managed to get a good technique going clockwise, will be strange doing a counter clockwise wind now.
Will post a pic in a bit of the finished humbucker.
Not too worried about how it looks as I will be making a cover/surround out of the walnut. The magnets aren't glued in place as I want to get some slightly bigger ones, either 8mm or 10mm. The main thing was getting it made so that I could pre-cut the cavity to size before gluing on the body wings.
Then with a straight edge clamped in place along the lines, scored it with a Stanley knife.
Then followed up with a chisel pressed in all the way around.
And out with the freshly sharpened 6mm chisel to remove the wood.
Tested the rod in place. Managed to get most of the way there, only a couple of mm to go, but had to down tools for the evening.
Should be able to get it finished tomorrow and then I can look at getting the fretboard in place.
Next up was masking tape over the top of the truss rod and then trimmed to stop glue going in the channel.
And then glued and clamped the fretboard in place.
Can see the fret position markers starting to show along the top edge.
Still need to sand level on the sides, slowly getting there, but I wanted to get the new body shape sketched in to give an idea of how it would look and also get the pickup position somewhere close to final location.
Hopefully you can make out the roughly shaped position of the pencil marks. Think it works...
Need to go over the radius again and take it up through the grades, but very pleased with how well the aluminium is looking.
Almost to the line. Just need to level it off and then I can start doing the rounding of the profile.
