I've heard one live. It sounded really good out front. The sound was a lot better than when I heard the same band the previous year and the guitarist had a Marshall half stack.
I've used a Pod live before in to the PA, and a guy who works as a guitar tech for some reasonably big bands told me it was the best sound he'd heard from me. The problem was monitoring and my sound on stage. I went back to using my amp. You'd need to invest in a decent rig for monitoring and hearing yourself on the stage.
The kemper is the only major item on my GAS list at the moment.
If you do a search on here there are quite a few rave reviews - mostly from me!!
In the studio it's freaking brilliant. Live (EQ-d properly through a good PA system) it's a fantastic bit of kit.
I've recently started profiling my own amps and find these a bit more to my liking than a number of commercial rigs I've brought
For direct recording, I am currently preferring the Kemper. It just sounds more realistic to me - like you've got an amp mic'd up in a live room and you're monitoring from the control room.
I'm not convinced it will sound as good as the Axe FX does through a poweramp and traditional guitar cab. I've only tried it a little bit though, so by no means am I an expert. But I'm not planning to use either of these devices live in the future - just not ready to do it.
So at the moment I am trialing the Kemper against the Axe FX, and even though the Axe FX does sound good.. the raw tones from the Kemper are sounding better to me.
I've profiled my amp, each channel, with the settings I use live... sounds really good.
I have a Kemper
Raw amp sounds are better than the AxeFx2, but FX are weak, and it's fiddly to use and switch FX on and off. Excellent for recording, but - not a live tool I think
Unlike the AF2, which would be perfect live with the pedal board
I'm saying the FX on the KPA are very basic multi-FX, nothing up to AF2 or Strymon quality
a dedicated floorboard would make it work for live, I agree
Personally, contrary to some opinions out there. I find the KPA nearly as fiddly to use via the front panel as the AF2, in a different way
Good for what they are, but
the delays are very basic, there is no multi band compressor, etc
