I had this thing wired up using older pots, basically anything that would fit, and it needed an upgrade.
The switching and tone seemed to be working ok, but one of the vols was a bit intermittent, so I ordered some new pots from Allegree.
I wasn't 100% sure which pots I needed for the vols, audio or linear taper, so I ordered 2 of each and a new paper in oil cap for the tone.
The plan was to take my time with it over Xmas, and to do as neat a job as possible, and I had to make a new pickguard which was basically 2 long straight cuts on a piece of 3mm white plastic, which I wasn't looking forward to.
Anyhoo, I started the pickguard yesterday, and amazingly I made a neat job of it, so today I had a go drilling for the pots and switch which also went smoothly.
I don'y have shielding tape right now, but I got a bit carried away and simply copied my existing wiring ( working ), and used the 2 new (assumed ) linear pots for the vols.
The other pots were marked A for audio, I guess, but the 2 I used had no marking other than 'Six string supplies 500k' so I assumed these were in fact 'linear' .
I tried to find some correct wiring diagram for this layout, 2 vols, 1 tone, 3 way switch, which was surprisingly difficult, and the ones I did find didn't seem to match what I had working, so I went with a direct copy of what I already had.
Strangely, it all seems to work, except I am finding the tone is slightly underwhelming, with a big drop at the end, so maybe I got the pots the wrong way round??
I quite like the sweep of the pots I used for the vols, and might have to swap out the tone pot for the one in my original wiring, a shame really, but the whole point of the exercise was to make it sound as good as I can get it.
I'll have to post a couple of pics to show what I have done, but any pointers to a good diagram would be nice.
This is the correct wiring for a V - obviously this is the '67-style control layout, but the '58-style is the same with different physical component positions.
Many other diagrams out there reverse the pickup and switch connections on the volume pots, which will not give you good tapers.
If you have A and B, use A for the tone control. It would be very unusual for a pot to not be marked at all, since it's quite important for many applications.
I'm going to be having another go at tidying things up next weekend when I will be fully shielding the cavity and back of the plate anyway, adding some more washers, and I was one length of vintage style wire short, which annoyed me.
It works, I'll get used to it.
If they are stamped "six string supplies" they are 25% log taper
If they are stamped "SSSP" they are 15% log taper.
The 25% are not great for tone controls....hence why they are now "old stock" (that was an expensive mistake)
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
