Gone: 2007 Gibson Custom Shop ES-339
Picked up a nice 335 which I was after so selling my CS339.
It’s a 2007 model, not a case queen, has some lacquer wear on the neck near binding and a couple of marks on body. Case has a bit of wear too as the guitar has been gigged.
Nice weight, well balanced, strong on the sustain end of things and very lively to play.
Based in Swansea, South Wales, happy to post or meet.
£1995
Specs and comments from online.
Features of note :
Solid center maple block
Laminated front, back, sides
30-60 neck profile
57 classic and 57 classic plus pickups
“Memphis tone circuit”
Side mounted jack
Construction and body style :
The ES339’s distinguishing feature is its smaller body. A tad bigger than a Les Paul, it is considerably smaller than an ES335, and has a solid maple block down the middle of the guitar. The feedback is considerably reduced, the guitar feels more comfortable to play standing up, and the overall tone is very different; punchier and more defined, while retaining the woody and airy nature of a semi hollow.
Neck profile:
Out of all the Gibson necks I have played, the 30-60 is probably the most comfortable shape I have encountered. It retains the quickness of the 60s neck, whit adding just a touch of girth that allows the hand to rest comfortably during more complex chords.
Electronics
The excellent 57 classic set. In my opinion, the finest pickup they make. If you are not familiar with it, do yourself a favor and try it out. The guitar also features a “Memphis tone circuit”, which essentially makes it so your high end doesn’t roll off with your volume. The Memphis Tone circuit utilizes 500K audio taper pots that operate with an interactive load that preserves high end as you turn down the volume. The loading effect preserves the full-bodied tone with rich midrange and singing sustain from the '57 Classic humbuckers while adding a very sweet bite.
