I recently picked up a cheap Fender Telecaster Player that someone had attempted to relic, hence the low price. It plays nicely, so I was going to keep it as-is, but the edges where the poly finish had been broken kept catching on clothing, so I thought I’d have a go at refinishing it.
So far I’ve removed the poly coating using a heat gun, so I’ll soon begin sanding to remove the remaining sealant and to try and at least minimise the gouges around the edges. As a bonus, I have ME/CFS (yay me!), so the sanding stage is going to take me a while, but at least it gives me time to think about the best way to finish it.
And… that’s where I’m getting a bit lost. I’ve had a good read of the various posts on here (although some of the older ones are suffering from image link rot) but it’s hard to get a sense of what the best option is likely to be. I’d ideally like to avoid anything too toxic both from a safety and environmental perspective, so a water or oil based approach seems like a sensible route. (Manchester Guitar Tech’s sonic blue nitro rattle cans and a vapour mask are tempting me though.)
Getting to the point, does anyone have any advice or suggestions for water or oil based approaches? Also, due to my ME/CFS anything that I can do in small, isolated chunks (ideally ~30 mins) over a period of days/weeks would be more realistic.
Of course, in an ideal world, I think a sonic blue colour would go well with the maple neck, but I’m happy to stain the body darker if that’s likely to be a more realistic goal.
To get over the sides problem @barnstorm mentioned I put a
I've had a look at the Fusion paints you mentioned and there's some interesting looking options in there, although I suspect I'd also need to add a layer or two of Tough Coat as I'm a bit of a clumsy git these days.
I think I'll see what the body ends up looking like once I've finished the sanding, as the oil option mentioned by @drofluf (great thread!) and @paulnb57 might be the way to go if the body looks good.
In terms of the ferrules, it was pretty easy - you can gently ease them out from the front through the string holes using an awl, although a blunt micro screwdriver might do the job if you’re careful.
Did you rub back between coats of the stain? (I’m guessing there’s a few coats on there.)
There were a few coats of Tru Oil and I knocked the coats back between a couple of layers. What I did do was apply the first coat fairly thinly, let that dry and then applied a similar one, before doing any 'hi build' layers, in case the oil lifted the stain any.
Hope that helps
I’m guessing that’s ash, so I can’t see the alder looking quite as nice, but even so.
Hmm… I might have to pick up a black scratch plate.
Just need to get started on the sanding when energy levels allow.
I’ll create a new thread as the build progresses, or perhaps just update this one.
