Up for sale is my 1965 Gibson SG junior which over the years has been modified into a SG Special.
It is a player rather than a museum/collectors piece, made to be gigged.
It has had a headstock repair with a spline which is solid and a neck reset that led to it being modified from a junior, it’s had a refinish during its life and been re-fretted at some point too.
When I bought the sg a few years ago it came with a pearloid guard (You can have this too) which looks god awful and despite not being period correct I had a batwing pickguard made for it.
The Original parts are:
Bridge Volume / Tone pots and control knobs
Jack Socket
Bridge Pickup - Hook up wire has been replaced during its life.
Bridge Posts
Non-original parts:
Faber Bridge
Kent Armstrong Neck P90 Pickup - Model S10
Neck Volume/Tone Pots - Japan 500k - unoriginal control knobs
Pickguard - Batwing and Pearloid
Gibson Deluxe Button Tuners
Bone nut
Switch craft 3-way toggle
The headstock and neck repair are solid, finish checking/hairline crack around headstock repair as shown in photos are settlement over the years (It was repaired many years ago) but is very stable and keeps in tune.
Frets are in good condition and have loads of life left, these were polished and filed 3/4 years ago.
The headstock veneer was replaced with a non-silk screen and was done at the time of the headstock repair but all of this was done well before my ownership 6 years ago so I’m going off what I remember from the previous owner telling me.
Nut and neck measurements:
Nut width 1 11/16”
1st fret thickness: 21.5mm
12th fret thickness: 24.2mm
12th fret width: 52mm
Neck profile is a hair thicker than a 1962 SG Special I used to own and this was far better than that was in sound/playability.
Weight wise it’s super light at around 6lbs and does suffer with the ill fated headstock dive some of this has been mitigated as the guitar originally came with gotoh kidney bean chrome locking tuners.
Plays well and sounds great.
In my ownership all I’ve had done was a setup, fret crown/polish, replaced machine heads with something more in keeping as the holes had previously been enlarged for locking tuners and a new pickguard.
I’ve been as honest as I can about the guitar and will try to answers questions as best to my knowledge as I can.
It’s vintage and certainly not a collectors but a vintage guitar you can use at a gig and not worry about it’s monetary value (Which I have a couple of times).
As of the last couple years it’s sat at home not being played as much, so with that it needs to go to a home where it will be played (The music I play doesn’t lend itself with this one sadly).
Also no relicing needed with this one as it comes with playing wear.
Value wise I have no idea as there isn’t anything in recent years to go by and I can’t gauge by non modified/undamaged examples. There are modified 1967 examples with the skinnier width neck for what I consider to be crazy money £2500-3000.
£1800
Based in Rutland near Stamford.
Here’s a link to the photos shown below:
Short video here:
Nut width 42.5mm
1st fret depth 21.5mm
12th Depth 24.2mm
12th fret width 52mm
May I ask what size are the frets? I struggle with old flat ones but if it's had taller wire fitted...
Id say the fret wire is the same height dimensions that are on my Gibson VOS 58 ES335.
Help me fund another potential gas purchase
