I am planning my next build. My last build was a strat and I have built a few Tele's.
I am thinking of having a go at a drop top strat, probably a mahogany body with a maple top.
This is new territory for me and I have questions I could do with some help with.
If I have a forearm bevel, how thin must the maple cap be for it to bend over the bevelled mahogany?
How do I deal with binding around the bevel?
I have made a top bound tele before and although I wasn't entirely happy with the quality of the final job, I am keen to have another go.
Wood binding, what wood and size might work best? How do I deal with the tight bends? Am I better off sticking with plastic.
Lot's of questions any help will be appreciated, Thanks
A couple of millimetres if you want a rounded bend. If the bevel transition is angled then you can take a triangular section groove out of the back of the cap, cutting almost all the way through, and bend along that. Both the depth and position of the groove need to be precise. You can also cut all the way through and rejoin, which leaves a noticeable join line. Another way is to use a thick cap, and chamfer that. I’ve also seen guitars where the chamfer just cuts through the cap to expose the body wood beneath.
I cut the channel in sections, and slightly shallower than the binding depth. I use an angle-adjustable router base, and adjust the router depth and angle for each section. Then I tidy up to depth with a sharp craft knife and straight edge.
Instagram
Thank you both for your advice.
Awesome.
Thanks. It might be a while.
Instagram
https://thefretboard.co.uk/discussion/231300/thinline-jazzmaster-with-body-curves#latest
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Thanks for that. How thick do you think that cap was?
