For sale is a Gibson SG Special 2007, acquired from the good gentlemen
@Kuras of this parish in 2021. It was previously advertised here:
https://www.thefretboard.co.uk/discussion/206141/sold-2007-gibson-sg-special
Everything is as in that advert, with a setup added in the meantime and D'Addario NYXL 10-42. Copied from there, with due copyright noted, and whatever he says:
- There was a headstock fracture from when it fell from a Hercules stand. Luckily it was a very clean, small fracture. The gap between the wood was barely a millimetre wide. This was expertly repaired by the fantastic guys at Waghorn Guitars in Bristol. They did a splendid job.- One of the tuners got knocked off during the fall, I couldn’t get hold of a Gibson tuner at the time so I ended up using a Schaller.- I replaced the knobs with witch hats, I do not have the originals.- I replaced with bridge with a Gotoh tune-o-matic, I no longer have the original.- I added surrounds to the humbuckers.I am looking for £400 collected from Cambridgeshire, or I can deliver in or on the way to Warwickshire.
- Nut width: 42.3mm
- String spacing at nut: 35.9mm
- Depth at first fret: 20.9mm
- Width at 12th fret: 52.6mm
- Depth at 12th fret:24.3mm
I got a similar one of these as Amazon B stock in 2016 for a bit more than this. The knobs were smashed in, it had obviously taken a nasty knock. I got it for modding anyway and it has become my most gigged and longest serving guitar. Definitely recommend
