Ive got an odd problem with Native showing two different options/names for presets in separate projects/instances of Native I have going at the mo. The example is as follows
Project 1 has all my user created presets listed at the end of the factory presets in folders named as "USER 3,4,5" etc in the dropdown
Project 2 has none of my created presets and at the end of the factory preset instead the folder its listed as "Setlist 3,4,5" in the dropdown which are all empty
So far I have uninstalled and re-installed Native, no change, same behaviour
Has anyone else had this issue and found a solution?
Its pretty frustrating as I can only use that one project to access anything Ive stored or created myself.
After you've done that: For the instance in project 2, follow the same process except instead of Exporting the bundle, select the Import Bundle instead.
The terms I'm familiar with are Presets, Setlists, Bundles and Snapshots
Do you mean different DAW projects?
So when you Import that 'bundle', I would expect things to look like they do in project 1.
When you export the bundle from project 1, do you use the Export Bundle button that I've label 1 in the picture below.
And when you subsequently import the bundle, do you use the Import Bundle button that I've labelled 2 in the picture below.
https://i.imgur.com/2MX0Gdg.png
Consider my hat well and truly doffed to you!
