If you want to really go to the extreme, you can sleeve the shield with thin heatshrink, and then a larger piece over the joint to make sure it's all covered, then you can get the shield pretty much right up to the terminal.
Alternatively, if the cavity itself is well-shielded, it doesn't matter at all.
