Hi all,
I've had a lot of fun recently rewiring and upgrading a couple of guitars. I'm getting to the point where I actually appear to understand what I'm doing and how guitar wiring works! May seem pathetic but after reading a load of stuff and experimenting it's just clicked and the fog lifted!
I built a new scratch-plate this weekend for my SoCal (couple of Suhr Aldrich pickups, Bourns volume with treble pass & push/pull with partial coil splits, 3 way switch) and all went well... except for some reason the volume pot seems intermittent. It seems to be a full volume irrespective of the pot position but then if I wriggle it a bit it starts to work (and then stops again). I've checked my wiring/work in detail and all looks fine. Everything meters correctly and I've been super tidy in my work.
Could I have damaged the pot (or it have a fault) as I simply cannot work out what's going on and why it would fail to full volume and appear to bypass the pot..
Next on the list is an inductor based mid-range contour control!
Who would have thought that this stuff could be so much fun and satisfying (excepting the above!).
Oh an one final question whilst I'm on it.. why do we use/require different resistor values for partial splits on a neck vs. bridge pickup? Answers beyond - they sound better would be helpful as I'm trying to understand what's actually going on
Any help appreciated.
Si
I'll double check everything again and have ordered a couple more pots.
Si
Changed the pot and appears to work now..
