Fretwork tape recommendations for maple neck.
Hi can anyone recommend a brand if tape suitable for fretwork when dressing the frets on a maple neck.
I have used some frog tape in the past and lifted it a couple of timea on a cloth to remove some of the stickiness  but still ends up pulling some lacquer off..
Been using metal guards which work but alot of effort making sure to avoid the fingerboard.
Thanks
  • Northwest guitars sell a very low tack masking tape. I tend to use that one on maple boards.
  • elstoofelstoof Frets: 2778
    Frog tape low tack plus wrap the tape around your forearm to pick a bit of grease up and reduce the tack even more before taping the guitar
  • KittyfriskKittyfrisk Frets: 20601
    elstoof said:
    Frog tape low tack plus wrap the tape around your forehead to pick a bit of grease up and reduce the tack even more before taping the guitar
    FTFY :D
  • mrkbmrkb Frets: 7430
    elstoof said:
    Frog tape low tack plus wrap the tape around your foreskin to pick a bit of grease up and reduce the tack even more before taping the guitar
    FTFY :D
    Dirty bastard ;)
    Karma......
    Ebay mark7777_1
    You want to reduce the stick, not make it tefal
    Thanks just ordered some off ebay
