Q: Is there any mechanical reason why a 3-a-side headstock is preferred over a straight-6 for guitars with a set-neck?
Is it just an arbitrary convention? I can imagine that being the case because set neck is a more traditional construction method. Pre-war brands would just carry through the headstock designs from their acoustic instruments.
Conversely, Leo Fender starts from scratch, comes up with the bolt-on neck and the 6-in-a-line headstock, and those things just pass into tradition as co-existing features.
Or am I missing something from an engineering point of view that makes 3-a-side headstock better on a set-neck?
Ta!
The early Bigsby guitars had 6-in line headstocks, which Fender borrowed. The first fenders had 3 a side.
1948 Bigbsy - this is a through neck, so closer to set than bolt on
1949 fender
Instagram
Instagram
Flat headstocks usually need some help with the break angle. String trees help with this, but there is less room for them on a 3 a side and a single bar hadn;t really been used at that point. That is likely why fender didn't stick with the snakehead
An angled 6 a side can be a bit weaker, especially if done in a wood like mahogany. Firebirds often suffer from having such a large angled headstock.
Another random consideration is overall string length, but this isn't really an issue on most electrics.
Instagram
hoo boy. the tip of the headstock on a firebird is so far away from the bridge and angled so far back behind the rest of the guitar. it's an incredibly awkward shape, it is just BEGGING to get knocked and break, and can't fit in 99% of cases/bags. can see why the 3x3 is more common on angled headstocks.
At the fancy end of things I've always wanted a Probett Rocket as well
My assumption has always been it had 2 benefits for Leo - cheaper & faster to make, and looked different to anything before, marking Fender out as the "new thing"
Instagram
eg. a tele and a Les Paul have different angles at the heel, but looking at the neck in isolation, once the strings are all but parallel with the fretboard, isn't the issue of break angle at the nut the same for both designs?
So a Les Paul could have and tele headstock and vice versa?
Instagram
Sorry misread - the bit in bold is incorrect.
Instagram
Note it is only the low strings on a flat headstock that have a comparable break angle over the nut. The rest are much shallower. String trees help
Instagram
Instagram
