Just done a deal on a sixties hofner hollowbody Bass and just a bit concerned about the truss rod.
its all original with a straight neck and good action ( only needed to lower the pickup) -but I'm a bit paranoid about Hofner basses and their truss rods as the last two I have owned ( 60s verythin basses ) had a snapped truss rod at the nut and a bodge repairs.
The neck is straight on the one I have but even taking all the tension off the neck it still is straight and when tightened it still does not have an effect on the neck - there is some scrapping under the nut which I think where someone was trying to either remove or adjust the nut. is this common on these early hofners basses ?
It is currently strung with flatwounds with a good action and plays fine but Ho not too sure to keep it or try to get a refund .
If distance selling regulations entitle you to return the instrument, consider doing that.
The nut comes off / and on but as soon as it hits the "" plate " stop dead.
Could the rod just fail and the tension pull it into a bow?
Thanks again
