Also, looking at the bill of materials, the cost of the Mouser order alone would be £123. Unless you desperately want to build your own kit (and it is a lot of fun) you might be better off buying a used T Rex Replicator.
Here's the video anyway:
JST crimping is fairly easy with some suitable crimping pliers, but again they're additional cost if you'd only ever use them on this project.
I never realised it used an Arduino, but I do have a couple Nano IoTs kicking around unused.
Arduino programming isn't that hard using the Arduino IDE, and having had a quick look over the supplied code, it is fairly simple to change settings.
My offer to do the 3D printing still stands, and if needed and somebody can tell me what's needed, I could do the JST crimping. I'll likely have all the required JST connectors anyway (they're one of two common connectors used for 3D printers).
