Tenor guitar — adjust nut file size choice
My new guitar is strung with the following light gauges:
10 thou
14 thou
21 thou (wound)
27 thou (wound)
I need to lower the action at the nut. (Bridge height is ok. Truss rod properly adjusted).
Decent nut files are expensive.
MusicNomad do a range of sizes at £23 a pop.
I don't think the Hosco Double Edged Nut Slotting Files Electric Guitar Set would work.
Grateful for advice as to the best to proceed for the least cost.
  • UlsinusUlsinus Frets: 0
    Oh and it's in 'Chicago' tuning ie DGBE.
  • ICBMICBM Frets: 74494
    You should be able to find a half-decent set with enough of a range of sizes - bear in mind you don’t need (and actually shouldn’t use) the exact sizes, the slots need to be slightly larger than the strings. If cut cleanly with a smooth rounded profile they can be substantially wider and still be right.
    ICBM said: [...] bear in mind you don’t need (and actually shouldn’t use) the exact sizes, the slots need to be slightly larger than the strings.
    Thanks ICBM.
