I'm playing far more acoustic guitar these days (that could have something to do with my new J-45) and I was becoming tired of the cheap spring loaded capo I was using, which always seemed to pull the strings slightly sharp.
So, I took the plunge after reading a few reviews and watching some YouTube videos I purchased the Performance 3 Capo from G7th.
At £35 it was the most I've ever spent on any capo but still not hideously priced especially when it's put to work.
Right out of the packaging it's a beautifully made thing and seems to be very high quality and engineered very well. In use it surpasses any other capo I've had the misfortune of using - it just works.
Just place it in the position you want and squeeze with just enough pressure to clamp it in place, and you're done! No springs to fight or screw clamps to adjust.
It has an adaptive pad which adjusts to the radius of the fingerboard, whatever guitar you happen to be playing - it reminds me of how a windscreen wiper adapts to the curvature of the windscreen on a car, the principle seems very similar to me, although in the blurb I've read it probably has a bit more science to it than that.
Because it adapts to the radius of the guitar's fingerboard it doesn't require excessive force to adequately fret the strings, which is the bugbear of other capos and which seems to pull the strings sharp.
To disengage, just press a little lever on the back and the pressure is released.
Whatever guitar I use and wherever I place it on the neck notes all seem to intonate correctly and I've not had any of the issues with strings being pulled sharp or having to adjust the angle to compensate and then having strings not being fretted properly.
The other thing I really like about it is the fact that there are no large sticky-out bits to catch on anything or whack your hand on in dumb moments and it's very unobtrusive in use.
I don't know why it took me so long to discover G7th capos or to buy one. I'm really impressed.
There's a piece of Nerina in every song that I sing
Bit of trading feedback here.
Feedback : https://www.thefretboard.co.uk/discussion/58125/
I had the original G7 (which I sold) and the performance I got last year - and TBH for me, even with the "new adaptive thing" (which is why I tried the performance) they both suffer the same problems, they really dont adapt to various fretboard radii well without "hard clamping" at least not for the guitars I have - especially so on the Brook
I think the Nashville is a much better capo, more versatile and a lot cheaper and seems to adapt to fretboards better
Im having same issue with the Furch and the V profile, its just too much of a battle
