Will this diagram be OK?
https://ibb.co/4ZFwVq9
On my smartphone, any image hosted on ibb.co gets elongated beyond all recognition.
Nearly - it doesn't need the ground moving on the tone pot since it's already connected. Just use the cap to connect the volume control input (switch) terminal to the tone control middle terminal instead of grounding the cap.
Personally, although the switch wiring will work as shown, I would also parallel all the pickup connections since that maximises reliability and minimises switching noise.
ie if you label the terminals in the diagram (allowing for the tilt!) as -
1 2 3 4
5 6 7 8
With the volume control to 1 and 8 (as shown), also connect the bridge pickup to 4 (shown) and 7, middle pickup to 3 (shown) and 6, and neck pickup to 2 (shown) and 5.
Does that make sense?
Then connect the bridge pickup coil split (red and white if it's a Duncan) to terminal 7, and either the volume control input or ground, depending on which coil you want to remain on, to terminal 6. Which coil remains on will make quite a big difference to the sound of the bridge/middle position, and also whether it's hum-cancelling or not. Unfortunately without knowing exactly what the pickups are or testing them, I can't say which is better, you may have to just try it both ways.
