It is bloody sharp at the edges & will slice your fingers when applying it unless you are careful.
Thinking about it, the mesh might be just as good at shielding if you could get it to stay in place
You do need to solder the pieces together (just a blob is fine) for continuity.
https://i.imgur.com/ILuIJMv.png
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
