Oak Pedalboard Build - Complete
strat84strat84 Frets: 328
edited June 2023 in Making & Modding
I've managed to get a start on a pedalboard build with the lighter nights and decent weather so thought I'd share my progress so far.
I bought 3 metres of 95 × 19mm Oak from Ebay as it was fairly priced, had some nice grain and looked to be straight and square. I'd already cut down my existing IKEA Gorm pedalboard to the dimensions I wanted the new one to be so was able to get started with the cuts. I only have 5 pedals so wanted it as compact as possible - About 400 x 300 mm with space for a power supply and extension lead underneath.
I was hoping to use hand tools only for this but the rip cuts were quite tough so ended up using a circular saw. This is the first time I've used any sort of hardwood, a bit different to pine
  • BigMonkaBigMonka Frets: 1820
    I'll be keep an eye on this as I've got plans to make something similar (although a little bit larger).
    Do you have a plan or sketch of what you're making?
  • strat84strat84 Frets: 328
    @BigMonka The only thing I've got is this cardboard cut out of the side profile, just so I could get an accurate layout of the slats. These are 45mm each and will sit through each side. The sides measure 55mm at the back up to 65mm at the front  ;)
    Joints complete. Not perfect but not bad for a first go with a saw and chisel. I did think about doing dove tails but this was stressful enough
  • nero1701nero1701 Frets: 1658
    Looking great!
    nero1701 said:
    Looking great!
    Starting to take a bit of shape -
    A spot of rain so I brought the fun indoors.. the Mrs was pleased with the sawdust all over the conservatory
    Everything has slotted together nicely, not far off glue up time
  • JCA2550JCA2550 Frets: 464
    You can be very proud of this it's going to be rather gorgeous.
    What's tasty looking handsaw you're using? Japanese?
    That's very kind @JCA2550 thanks, I am quite pleased with how it's turned out so far. It's actually only my second wood working project after acquiring my Grandad's power/hand tools.
    It is a Japanese saw yes. Double edged for cross/rip cuts. The longer toothed side wasn't that great for rip cuts in this Oak but the smaller teeth are superb for cross cutting.
    JCA2550 said:
    What finish are going to use?
    That's something I was going to ask here as I know nothing about wood finishing  :)
    Main body glue up done. A couple of small gaps to fill but nothing major, all pretty square. Last pic is it sat on some IKEA furniture feet
    Next job is to cut the slats just oversized and finish with a flush trim bit once glued in.. then roundover all outside edges which I'm a bit nervous about
    That’s looking lovely, great job! Be a shame to cover all the lovely oak with Velcro!
    In terms of finish you could just oil it (with varying degrees of darkening the wood available) or for a bit of extra robustness you could use a hard wax oil like Osmo PolyX (super expensive), Fiddes, or Treatex.
    Thanks @BigMonka - Yes it is. I may use thinner stuffed than I had planned just so less is covered.
    Cheers, I'll look into those. Does the hard wax oil darken the wood? I quite like the colour as it is, although I wouldn't mind darkening the end grain of the slats.
    Just wanted to show what kind of cross cuts you can get with this Japanese style saw. It was relatively cheap as well, £18 I think.
    @JCA2550 ; ;)
    Each slat needed a little trim before glueing in.
  • rsvmarkrsvmark Frets: 1474
    I can recommend osmo for oak. I did a load of work to my house over the last year or so and had lots of oak- stair case, window seats, ledge and brace doors, liners and architraves. Love osmo for oak
    An official Foo liked guitarist since 2024
  • richman6100richman6100 Frets: 373
    @strat84 That's an excellent, professional looking job. Consider me seriously impressed! As @rsvmark says, Osmo is great stuff and I've had really good results with it. Others on the forum may be able to contribute other suggestions of course. I'm really looking forward to seeing this finished with some pedals on board.  :-)
    Cheers guys and thanks for the kind words @richman6100 ; :3
    Have just ordered some 5ml samples direct from Osmo, free of charge and no postage cost! I ordered clear satin and clear matt, just to try on a scrap piece.
    I was wife and childless this afternoon so managed to get in the garden. Not a great deal of progress but all glueing is done and the slats are trimmed flush.
    I decided to use a pattern bit instead of a flush trim so I could take very small amounts off at a time. There wasn't much to begin with but I didnt want any balls-ups at this stage  =)
    edited May 2023
    I've spent a bit of time testing roundover sizes on some scrap. I was planning on doing a 1/4" radius or perhaps a bit bigger but quite like the look of this at 3/16" -
