What pickup could I put in this little piece of sh..
For slide.
  • NeilybobNeilybob Frets: 947
    Not sure of many pickups available for 5 string guitars lol
    Aynsley Lister had a P90 installed on his old semi acoustic
    https://www.instagram.com/p/CjU9qkCMRvF/?igshid=YmMyMTA2M2Y=
    flanging_fed “
  • bobaccobobacco Frets: 579
    Seymour Duncan Invader.
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • TheMarlinTheMarlin Frets: 8499
    Charlie Christian?  You can get some that mount on the end of the neck
  • Winny_PoohWinny_Pooh Frets: 8078
    edited May 2023
    If you play with OD then a humbucker at the bridge sounds best IMO. But, a dog ear P90 will look right and can be shimmed up suitably.
  • lovestrat74lovestrat74 Frets: 2676
    Forgot to say.. Something cheap, dirty and bluesy to match the guitar.
     A lol and a wow there! Wonder how that is held in?
  • SvartmetallSvartmetall Frets: 756
    Axerus do a nifty-looking worn copper HB cover, maybe fit something into that?
  • ICBMICBM Frets: 74494
    Are you planning to cut a hole in it? If not there's only fairly limited clearance between the strings and the top, which will restrict things. If you are, beware that the top braces might be fairly closely spaced, and a pickup hole might conflict with them. Don't cut through them :).
    Not sure yet, but I'll keep a close eye on it :)
  • FunkfingersFunkfingers Frets: 15276
    edited May 2023
    Dogear P90 or one of those little Jazz pickups with a fingerboard bracket.
    FWIIW, I have a NOS Seymour Duncan Johnny Smith pickup but it is probably worth several times more than the POsh..
    Based on a friend's early Sixties ES125, one P90 near the neck should suffice.
  • elstoofelstoof Frets: 2778
    Kent Armstrong floating
    Maybe something like this with a 10mm height would work by mounting it to the body.
    Or ping Marc at Mojo pickups and see what he suggests?
    flanging_fed “
  • prowlaprowla Frets: 5119
    Something surface mounted - not sure if a Ric Toaster would fit?
    Got to be something less than the guitar. Don't see the point of putting £100 pup in a cheap guitar
  • GrangousierGrangousier Frets: 2797
    edited May 2023
    Perhaps someone has one of those foil-type pickups from a 1960s Woolworths guitar - measuring it, it's about 9mm deep, and you could probably jerry-rig some kind of mount. I have one, but I'm holding on to it in case exactly this sort of thing arises in my life.
    Probably sound terrible, but in an authentic way.
  • steamabacussteamabacus Frets: 1292
    CH Guitars do a cheap neck-mount humbucker (although currently showing 'out of stock')
    edited May 2023
    Alegree does one under £30 so I think I'll go down that route. Should be quite a fun (and cheap) mini project!
  • I've an old Dimarzio Super Distortion that came out of my 82 Westbury Standard.
    Don't let your mind post toastee - like a lot of my friends did!
    edited May 2023
    PM me if you want to sell it @Crazed_Fandango ;
    1
  • sweepysweepy Frets: 4268
    Dog ear P90 ?
