Burny Les Paul, Ibanez RG2620QM
Based in Bolton, Greater Manchester.
Guitars set up by Eltham Jones Bristol.
(further pictures at the end of the listing)
Super lightweight at 3.4 kg (7lb 8oz)
Bone Nut
Stainless Steel frets 1.3mm high
'59 profile neck 1st fret 21.3mm; 12th fret 23.9mm
Push-push tone pots for single coil emulation
Tonerider AC2 Humbuckers
Comprehensibly shielded with foil / graphite
Gotoh ABR-1 bridge (The neck angle is perfect and so the strings don’t touch the back of the bridge en route to the tailpiece)
Gotoh GE101A Aluminium Tailpiece
Ibanez RG2620QM £750
Stock specifications
Petrucci switching
