Rarely seen, top of the Yamaha RGX line - neck through guitar. Late 80s.
https://photos.app.goo.gl/sFVhvaRSx8jFRiDe9
Made in Taiwan.
Think this is the silver pearl colour.
24.75 scale
Alder body
Mahogany neck through
ebony board
Rockin magic pro trem
3 single pups
side mounted jack.
Condition wise, it looks great for its age. There is a paint chip on tip of the headstock and 3 or 4 small scratches mainly on rear and 2 or 3 very minor dings on the edges. It has clearly had an easy life.
There is no trem arm - The trem is currently blocked off.
*The electrics are a bit of a mystery to me as I've no technical ability whatsoever.
The guitar has 3 switches at the top which apparently do things such as direct over ride, out of phase etc. The info is out there on the net.
Whether these work as they should, I couldn't honestly tell and I've never really used them. Things do happen - just not sure what! The pots/switches are a little crackly. But it sounds fine once you've selected everything and play it!
Welcome to try it. Pretty sure first to try will buy!
