I'm not an expert, but if your solution fails the visual inspection part of a PAT test and you use it without the magic sticker, it would probably invalidate the venue's public liability insurance.
Panama 1x12 Speaker Cabinet w/ Built-In Attenuator https://reverb.com/item/9944856?utm_source=android-app&utm_medium=android-share&utm_campaign=listing&utm_content=9944856
flanging_fed “
- yes, I am talking about the back panel which gives access to the valves. I'm thinking of tool-free valve changes during a gig (never happened so far!)
- this will be gigged but the PAT regulations are not relevant as I live in Argentina. The amp has been well-built and properly tested so I'm' not worried!
- Those latches seen on the Panama amp would work but they're a bit heavy duty for this use (bulky and heavy)
- Roller latches are a good idea... I reckon they'd rattle but worth further thought.
- Velcro doesn't convince me much as a solution to anything (even my pedalboard is velcro-free)
The magnets I have are neodymium washer-style with a hole in the middle for a screw to pass through. They would be plenty strong enough. My only doubt is the magnetic field mentioned earlier. This whole thing is on top of a speaker with a huge magnet so I would guess there'd be no issue, but the magnets would be near the power transformer on one side, and fairly near the (shielded) V1 preamp valve on the other side.
Type A
https://magnetsales.co.uk/products/office-magnets/
Magnetic strength decrease in distance in a inverse exponential curve, meaning that a small change in distance greatly reduces the pull strength/magnetic field. Just keep them away from valve and transformers and you should be fine.
Fit little ribbons loops to put your fingers through to pull the panel out.
One end of the panel would have the magnets ~2cm from the toroidal output transformer. From what you said, this sounds like it may be an issue? If so I'll just go with boring screws.
At the other end, V1 is probably 8-10cm from where the magnets would go.
